Images & Sidebar Not Showing on Category and Posts
I added in a sidebar but for some reason, it’s not showing and some of my posts, images have disappeared.
Link to site here: http://belltimemagazine.ie/category/languages/
Sample post: http://belltimemagazine.ie/students-beginning-crowdfund-college-fees/
Images are there.
What seems to be the issue???
Hello bellmedialtd,
images not displaying on site – reply
#107680
Apr 22, 2016 at 5:06 pm
Hello saffamatt,
I have checked your website and I saw that you have some js errors in your console. I suspect this issue come from your untested plugins which interfere with the theme and could create some unknown issue. Please try to disable all the active plugins, leave just Visual Composer to active, clear all cache and install only the plugins that come bundled with our theme and rule out the conflicting plugins. Before this, you can try to disable the lazy load feature from theme panel if this is active, like this -> http://screencast.com/t/Wmjkad9U
Also, please try to update the theme to the latest version (6.7.2) and the Visual Composer (4.11.2).
Thank you for the message!
