Importing Blocks Problem
I am trying to use the page builder to create my website. When I attempt to import a block to use on the site, the question “Are you sure you would like to import this block?” with the options yes and no show up behind the preview. Because of this, I am unable to select OK. Is there anyway to fix this?
Hello !
Thanks for your response! Unfortunately, I did as you recommended and the problem still occurs. Is there anything else that you suggest? Thanks
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
PLEASE NOTE THAT DUE TO THE HIGH SUPPORT REQUEST THE RESPONSE MAY GET DELAYED UP TO 48H !
