Importing function and Mixing Theme Versions
2. What do you mean “I not sure if is what you mean”? I sent to you the url that I want.
hxxp://sensacionalista.uol.com.br/2015/04/28/pai-que-tatuou-filha-no-rosto-se-explica-queria-afastar-a-possibilidade-de-fazer-outro-bebe/
Just replace the “xx” to “tt”, your answer just allign the ads in the left side, I need the allign of the text. Click on the link.
10. This solution doesnt works very well because adds a small black rectangle connecting the images, in the inferior of the images, as you can see in my site: hxxp://concursospublicos.ninja/
How fix it?
2. According to this answer in Envato:
“You have to edit the post template files (in your link you use the default post style) and add the following code above the title – http://screencast.com/t/m2DbSDPJHXm – http://screencast.com/t/r8h7cmRU4V – http://screencast.com/t/6fEYKR6pCc
<?php echo td_global_blocks::get_instance(‘td_block_ad_box’)->render(array(‘spot_id’ => ‘custom_ad_1’)); ?>”
And after did that:
A new problem, see this image: http://imgur.com/PulWxKa
Sidebar above the ads and a fourth ads in the post. Can you offer a real solution?
Replied via Dashboard. Please try to use only one section, it’s hard to follow the questions/answers posted forum, continued on Dashboard then jump to email and back to forum. We take all messages in order, from the oldest to the newest.
Thank you, Emil G.
Look, your answer didnt work for me. You already have my login and password in your email. Please dont answer with a large answer, try by yourself and see the problems of your answer. My code of adsense have 336×280.
I want this:
and eliminate this:
1. The top and the bottom ads are outside the content, you can only achieve that position by using the Inline Ad – http://screencast.com/t/bpfr7TVO1sp
Play with the paragraph (add 1 or 2) and test to see if the ad jumps in the position you want. The theme function breaks the content into paragraphs and you can select after which paragraph to display the inline ad.
After that set it’s position – http://screencast.com/t/eaYoJ6gfKK9
2. I already provided a custom css in the image from the dashboard: – http://screencast.com/t/OflIC1U7P
.td_module_mx1 .td-block14-border {
height: 100%;
Add the css in Theme Panel -> Custom CSS.
Some modules have extra elements like lines, shadows, etc, when you change the thumb size or other module parameters you also have to consider those elements.
Thank you, Emil G.
Viewing 5 posts - 26 through 30 (of 30 total)
