We use newspaper theme on our website chemicalindustryjournal.co.uk and we use a plugin called adrotate that manages ads on our site. Before we updated to newspaper 12 the stats for impressions from the header and the sidebar were consistently the same but since we have started to use the cloud templates the header stats have dropped down dramatically.
We use shortcodes in the ad box in header to place the ads and in the sidebar too, see screenshot, and we are just trying to work out why this is happening, does that make sense?
From the images the settings are done ok for the ad box. It is possible that it is just a period, but if you think that this situation is possible from cloud templates, maybe it would be better to do a test, set a classic header (which was used before) and see if the header status returns to the values it had before.
Thanks a lot for that Calin, that is a good idea.
Can we still use the classic header in version 12.7.3?
I have turned off the cloud template header and looking to put the header back like version 9 but can’t see the options to have a header logo to the left and ad box to the right, like screenshot.
Can we do this in the theme panel?
Hi Sim2,
Yes, you can use the old templates; for this, you just need to make sure that the plugin tagDiv Standard Pack is enabled. This can be installed/enabled from Newspaper > plugins https://i.imgur.com/xRM2JwH.png
Then in the theme panel in the header section for cloud, make sure is set the -no template- and choose the header style you need (i think is style 1) – https://i.imgur.com/QFTEkF2.png
