In TagDiv, when I click a block on the right, the left pannel is not responding
https://holygeneration.life
Problem 1# In TagDiv composer, when I click a block on the right side, the left pannel is not responding as it used to respond before (I am trying to edit a block on the home page).
Problem 2# I see the following error on a block. How to correct or remove this?
[td_block_big_grid_flex_1 grid_layout=”3″ image_height=”eyJhbGwiOiI3MCIsInBvcnRyYWl0IjoiODAiLCJwaG9uZSI6IjUwIn0=” image_zoom%
  • This topic was modified 6 years by MarkIndia.
1. When clicking on the elements in the page or template, the left sidebar should display the options for it. If that is not happening, then there is a problem. Does it work correctly in a new page? Was the page built entirely with the composer?
2. Did you make any modifications to the code of the page in the backend? This may happen if the page is broken, or there were modifications to its code – https://prnt.sc/r3iyfp
If these issues are happening only in a specific page, then you could try and restore an older revision, before the problems happened – https://prnt.sc/r3iz6h
If it’s happening for all the pages, even new ones, we could take a closer look. Send us an email at contact@tagdiv.com and provide admin login.
Hello Simion,
I have sent you the login details by email (for https://holygeneration.life)
Please check the email (contact@tagdiv.com) and solve the problem on my wordpress site. I am waiting since so many days.
Hello Simion,
You wrote:
{{{If these issues are happening only in a specific page, then you could try and restore an older revision, before the problems happened – https://prnt.sc/r3iz6h}}}
I followed this instruction and the problem is solved 🙂
Thank you so much! Now the site is working well!
If you facing other problems with our theme, just let us know!
