Inarticle Adsense on mobile problem
I have a strange problem with adsense inarticle ads on mobile.
Even if they are inserted apparently with the right dimensions (330 x 275 x)
It happens that they are displayed inside a div that makes
them expand off-field incorrectly…
<ins class=”adsbygoogle” style=”display: block; text-align: center; height: 500px; width: 600px;” data-ad-format=”fluid” data-ad-layout=”in-article”
I don’t understand if it’s an ad problem or the ad script that adapts to something wrong in the mobile theme…
Ads are inserted via newspaper interface from control panel in the ARTICLE INLINE AD and ARTICLE BOTTOM AD fields.
In order to test this implementation, try to use the adrotate plugin and place the ad inside the plugin and then place the plugin shortcode in the mobile theme ad spot in the theme panel. This way you bypass the theme ad system and see if the ad potions the same.
Hi Bogdan,
I did a simpler thing
I removed the ad from the mobile theme panel and inserted it directly into function.php with a function that puts it after two paragraphs.
the result does not change
Sometimes the announcement is only partially displayed with a div 600 x 500 that causes it to exit the smartphone screen…
Any suggestion?
Well, if you bypassed the theme ad system, it is clear that the problem is not from there. Are you sure the ad is responsive. Please test this on a wp default theme. Is this behavior only happening in our theme? only on the mobile theme? does it happen on a wp default theme? These are standard debugging methods needed for the investigation.
Hi Bogdan,
after a thorough analysis I believe that the problem is due to the mobile theme in relation to inarticle ads by google…
Any suggestion or attempts to resolve?
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
