Incorporate javascript into Head and Body
I need to add some advertising javascript to the Head and Body areas of the web, but when I add them to the Header.php file they are not shown on the web.
If I add them through Custom Code the problem is that they work in the whole page, not only in the Head and Body zones. Any solution?
  • This topic was modified 5 years by Beldar.
If the code needs to be add in the head and body, then please try to add your code in Newspaper -> Theme panel -> Analytics/JS => https://www.screencast.com/t/nou4AMaBhSMn codes and see if it is working or not.
Hope this helps you!
