Increasing speed with disabled standard pack
Hi!
I would like to disable the standard pack in order to achieve maximum speed! Can anyone help me with this process? Some pages were created with td, as well as my header, others are standard.
Hello !
My personal recommendation would be to for you to try a PRO Demo. PRO Demos automatically switch your elements in order to have it easier for you to deactivate the standard pack plugin.
Hello Vlad, thanks for your answer!
Trying a PRO demo means re-developing the entire website, doesn’t it?
It would be really time spending.
Is there any other way to convert the whole website, considering that almost every page is developed with tagDiv composer?
Hi there! I deactivated the standard pack, running with tagDiv composer only right now, but NO REAL IMPROVEMENTS on performance.
Hello !
Please provide us a link to your website in order to inspect !
Hi Vlad,
http://www.business-pills.com
Thank you
Hello !
You can take a look on GTMetrix over the Waterfall as you can see here: https://gtmetrix.com/reports/www.business-pills.com/qr5DamJ6/
You have Ads that are taking up resources, cache and cookies. Most of the issues are not Theme related.
