hi,
I have a little question about cloud templates,
if I set the noindex in robot.txt or yoast on the cloud template. does that mean all posts, which use cloud templates, have noindex settings?
or all posts can still be indexed separately with a cloud template.?
Hello !
For this we recommend you to use the SEO Yoast plugin as you can see here: https://imgur.com/ApOXLWp
