Hi. Should we index or noindex header or footer templates? Google sees them as separate pages and that is not good for SEO or/and for what google understands for a website? If we do them as noindex, will that affect the sum of the page where a cloud header/footer shows up?
Usually we recommend to not index them, there should not be any problems, (you need to use a seo plugin for this, for example Yoast SEO -> https://imgur.com/ApOXLWp)
