Individual problems after changing theme to Newspaper
I come from another theme and have installed Newspaper. I am very happy to have started to change to Newspaper but have a few issues that I am not sure if it is normal behaviour or not:
1. In the footer there are old widgets that I cannot address or change.
2. Visual Composer: “Disable Row” does not work, Single Image Lightbox does not work, Single Image Styles (3D shadow…) are not working.
3. Tag Div Composer: Starts but it is not possible to save a post created by tag Div composer.
4. Weather Widget: The Translation of this great plugin into German is correct (cannot be changed by theme panel), but upper and lowercase (A/a) is not correct because all words are written capitalized. I could provide you the correct version, if it would help you. Just let me know.
Many many thanks in advance!
Andy
Hello cobelfret,
1)First of all, please provide your website so I can take a closer look at your footer section. About what kind of widgets do you are referring? Provide more details/screenshots so I can saw the problem.
2)Notice that we do not recommend using the both plugins to be active at the same time because might appears some errors in the theme, sorry! For more information about our page builder and transitions between these two plugins, please check here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/ -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
3)Notice that TD Composer has not been designed to be used for post pages but only for pages, sorry!
4)I guess that you are referring to this Weather Strings -> https://www.youtube.com/watch?v=KSRYDLJkqe0&feature=youtu.be? Notice that translations come from WordPress and not from our theme, sorry!
