Infinite Load loads the same posts
I have blocks whit infinite load but the same 10 posts are loaded every time. I already disabled all plugins except Visual Composer but the problem persist.
If I set the Offset for 10 everything works perfectly but the first 10 posts doesn’t appear.
https://cubogeek.pt/novidades/
Tks
This could not be a plugin conflict but rather a js optimizatuion/minification The images on your site do not load and the js elements such as the search do not work: https://www.screencast.com/t/WqYlipKJi5v It is clear that a js error is affecting your site.
Please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Hi Bogdan,
Thanks for pointing out the error in the images and the search bar. I think that is resolved.
But the infinite load error has to do with a theme error.
A few days ago the “Warning: A non-numeric value encountered in” error appeared and a member of the staff said to change the offset to “0”. This is what is causing the error in the infinite load.
I ask you to try to solve this as soon as possible because I can not have the error to be displayed in the posts and the navigation of the site is based on infinite load.
Tks
Hello portuga,
I have checked on my side, and the Infinite load for Blocks seems to work as expected, without any problems. I have checked your console and I notice that you have some js errors which can come from your untested plugins. I checked your source page and I saw that you do not disable all of them. Please try to revert the theme to the default state, without any untested plugins, leave just Visual Composer, clear all your caches and check the results. Also, if the problem is still there, please try to make a new fresh install via FTP way, clear all your caches and check the results.
I downgraded to PHP5.something, and that solved the problem. I will wait for the theme to be updated.
Tks.
