Infinite Load Post Image Size Problem
Just bought the second license for my another website.
the website is http://www.dailyinspirationalquotes.in
I am using Block 13 in two column in my front page with 5 post limit by default and after that infinite load,
but the problem is, the first 5 images is showing proper and after the 6th image all the images are not resizing and displaying as actual and looks garbage.
can anyone please help me to sole this problem.
thanks
regards
Hello kapson,
I have checked your website and I saw the problem. I suspect this issue come from your untested plugins that you use them. This type of plugins creates some interference between our theme and these plugins and could cause these errors. Please try to disable all the active plugins, leave just Visual Composer, clear all cache and install only the plugins that come bundled with our theme and rule out the conflicting plugins. I have tested this case on my side and everything seems to work as expected.
I checked disabling plugins also but seems not worked.
But I noticed one thing after installing new theme, the new posts thumbs are loading properly, only old posts thumbnails are looking garbage.
should I need to regenerate all thumbnails for new theme? (like this tutorial: https://forum.tagdiv.com/existing-content/)
kindly help me decide so I can try it.
thanks
regards
Hello kapson,
I have checked your website and saw the problem with the thumbnail. For some posts you do not have the thumbnail and is shown only the image.Please try to regenerate your Thumbnails with this plugin and check after if your problem is still there. For more information about these problems, please check our documentation here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/ Please clear cache and purge your files if you use CDN.
Thank you for the message!
