Infinite load posts
I can’t seem to find this option, but I would like to disable infinite loading of new posts. Is there an option for that?
BR,
Filip
I’m assuming that this problem appear on posts that have set infinite loading, you’ll need to edit the single post template with tagDiv Composer and disable the infinite loading.
-> https://tagdiv.com/infinite-loading-for-single-posts/ from post -> https://i.imgur.com/yIf6fA3.jpg -> https://i.imgur.com/KeclHLS.jpg -> https://i.imgur.com/4jHIHFY.png
If this is not what you mean, please provide some more details and some screenshots.
Thank you
