im using the td_block_22 on my mainpage with td_ajax_filter and infinite ajax_pagination without stop. When i open my mainpage in the browser again the infinite load for the inital category “ALL” works fine. But when i change the category with the ajax category filter the infinite loading dont work. It only shows up 5 posts…
The same when i click back to “ALL” – the infinite loading dont work (DONT TRIGGER). When i refresh the site with F5 it works.
In your Demo http://demo.tagdiv.com/newspaper/block-16/ – the last block with the title “3 columns with INFINITE LOAD” there is the load more button – but if i click on a category “style hunter” and then back to the “ALL” it only shows one row instead of loadind all the posts. As mentioned before, im not using a load more button – just infinite loadining without a load more button and without stop.
Seems like a bug
thx
This topic was modified 10 years by
newtag.
I can assure you there is no such bug on our demo. It only shows the first row and then it loads the rest. I have tested your exact conditions and there was no bug at all.
Please test this on different browsers and different machines to see if the problem is not local. I tested the infinite loading again and it works as expected.
If you still have issues with this, please provide a link to your site pointing to a problematic block so we can inspect it as we cannot see the error on our demo.
How can I test a block from visual composer without visual composer? The blocks in our theme can only be used with VC. If you have problems with the pagination please disable all your plugins except VC, clear cache and reset cdn files. You could have a plugin conflict that is affecting the pagination.
Hi Bogdan,
Definitely I can verify that there is some bug here – tested no plugins and on different browsers.
Steps to reproduce:
1) Scroll to let infinite scroll load a page
2) Scroll back up and click a filter (e.g. ‘All’)
3) Scroll down again and infinite scroll doesn’t trigger
I’m currently digging as to why, but I can confirm that to get it to work after the above steps, you need to call the function in console:
tdInfiniteLoader.computeTopDistances()
Then the next page displays and infinite scroll works again.
Everytime I go on to click a filter, I must repeat the above steps to get it to work again as well. Possibly the below setTimeout function to trigger the computeTopDistances() call is not executing after filtering occurs.
case "infinite_load":
setTimeout(function() {
tdInfiniteLoader.computeTopDistances();
"" !== a.td_data && tdInfiniteLoader.enable_is_visible_callback(c.id)
}, 500), setTimeout(function() {
1E3), setTimeout(function() {
}, 1500)
Also can confirm the reported issue occurs in your demo:
Only 1 row renders – no infinite load, no Load More button
Please try this custom css for load more button ->
.td-load-more-wrap a{visibility: visible !important;} -> http://prntscr.com/q0l063
