I noticed that infinite loading was a bit sluggish. It seems to only load once you scroll all the way to the bottom and sometimes the user has to was a few seconds for it to show the next set of posts.
Would it be possible to start the loading before you reach the bottom? like 600px away from the bottom or something.
Also any other tips on making it load faster?
thanks
I also tested this and is loading more than once when you scroll down on block infinite pagination. To improve the loading speed look the mysql query cache: http://dev.mysql.com/doc/refman/5.1/en/query-cache.html We also use it on our demo.
Hi Alin,
Since the query cache has been deprecated, what are the ways to speed up and remove sluggish behavior now?
Hi ankitchugh,
Please try those guides for improve the loading speed by using the mysql query cache:
-> https://dev.mysql.com/blog-archive/mysql-8-0-retiring-support-for-the-query-cache/
-> https://www.digitalocean.com/community/tutorials/how-to-optimize-mysql-with-query-cache-on-ubuntu-18-04
I hope this will help you!
