Hi guys,
I have a problem with infinite scroll and/or load more function.
When I use this and more articles load, 5 of them are the same ones as the ones that were displayed already. This is how the block looks like after pressing load more button once – http://postimg.org/image/ayuo97bh9/
Notice also the dates of the articles. They go from 7th of january to 6th and back to 7th.
Is there anything that can be done about this? Is it a bug or is it something that can be set up?
Web: androidportal.sk
Please make sure that you don’t use the unique article feature on page as this is not working well with the infinite load pagination.
The dates issue could also appear due to this so please make sure you don’t have the unique articles feature active and let me know.
I have also made some tests to recreate this but haven’t found any issues with it. If you still have this issue make sure that you’ve set it right then also check this without plugins to make sure a plugin isn’t causing it.
The unique articles system is present on default page also. If you don’t have this option make sure you have it enabled from screen options: http://screencast.com/t/X4qn1e3Z
