Infinite Scroll on Single Posts with Advanced Ads
I currently use Advanced Ads for automatically placing my ads based on the content length. I want to enable Infinite Scroll on Single posts, but it looks like I need to use a Cloud Template? If I use a Cloud Template, I can’t use my Advanced Ads, I can only place three ads per post? Is there a workaround to allow Infinite Scroll without the Cloud Template? Or a way that the Single Post Template will auto insert my ads?
The infinite loading works only with cloud post templates. The initial post must use a cloud template where you can enable the infinite load, for the rest of the posts that are loaded is not necessary.
The theme provides 3 ad spots for the article content, both for the default post templates and also for cloud templates. Other than these, more ads in the post content could only be inserted with plugins maybe, or directly in the content manually.
Note that in the cloud post templates the ad codes have to be entered in the composer directly, in the post content element – http://prntscr.com/o7a8oc
Please let me know if you have more questions.
