Infinite Scroll Problem – on Mobile not working
the theme is great, but i have problems with the infinite scroll on the mobil phone. There it is not working it is not loading next page?
https://www.vitaes.de/
https://www.corporel.de/
on my other sites , it works great? but they have the same plugins and config..?
So i need your help to fix it…
Hi on this site it works great, so i dont understand the problem..:-(
https://www.nageldesign-magazin.com/
https://www.ratgeber-haus-garten.com/
https://www.bodyartnet.com/
On the desktop view on all sites works great…
Thanks, Jan
i found the Problem on the config, it works only on the “same categorie” in the mobil version..not only “next or previous post”
Did you solved your issue?
If not, then we can take a look if you contact us at contact@tagdiv.com and provide wp-admin. Also paste a link to this topic so we can easily identify you.
