I am trying to activate infinity load Similar to Demo site of Infinity scroll.
This is my site:http://bit.ly/1P3acOY
Bharath
Please find the screeshot of theme backend setting for infinity
http://www.screencast.com/t/iCQA1bAhDF8 -http://www.screencast.com/t/PYl7cn0tTjyj
You have some js errors in the console – http://screencast.com/t/34OwQAljk23 please disable all plugins leave just Visual Composer active, clear cahe and check again. Also try this without any css/js minifications.
Hi Alin,
I have removed all the plugin except VC, and removed all Css/js minifications, but still not working. Check the site now.
Bharath
Did you checked your console when you have deactivated all plugins? You still have these errors – http://screencast.com/t/wywwCnMl that affect also Big Slider.
These js errors usually are caused by plugins that conflict with theme javascript. Also please make sure that you use the latest theme version (4.6.3) and use this guide if you need to update(FTP method) – https://forum.tagdiv.com/how-to-update-the-theme/ also update the plugins that come with the theme’s files.
If still have this issue please send an email at contact@tagdiv.com and provide wp-access so we can take a look, also paste a link to this conversation so we can know who you are. We will answer to this soon as possible.
