infite scrolling problem when there is theme update
I have an issue with infite scrolling feature on newspaper theme. Whenever there is an update for the theme, this ajax call fails: https://potkrovlje.ba/wp-admin/admin-ajax.php?td_theme_name=Newspaper&v=10.3.9.1
The current version of the theme is 11. So whenever there is a new version if i don’t update it on time, the infite load and ajax load more button stop working until i update the theme. After i update it, all is working correctly again
Is there a way to stop this from happening.
There should be a plugin conflict, that’s why, please deactivate ALL plugins one by one except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and in this mood you will find out which plugin causes the problem.
Why would a plugin conflict cause this issue, and when the theme gets updated it continues to work (without me changing anything in the plugins) Again this issue happens when newspaper theme gets new version (i see in the panel message about new theme version) and i don’t update it immediately. I have a no way to test this, only to wait for the next theme update and try your solution.
ALso can you tell me what is the significance of this ajax call – https://potkrovlje.ba/wp-admin/admin-ajax.php?td_theme_name=Newspaper&v=10.3.9.1 – because its failure stops infinite scroll from working.
This issue may be due to a firewall blockage for the admin-ajax.php, can you check with your host if the admin-ajax.php is free in their firewall or if they have any knowledge of issues with it ?
