Ingnoring Offset posts when ajax filter is selected
We have a page with a Big Grid 9 element at the top, and a Block 13 element below it. The Block 13 has Offset posts set to 4 so that there are not duplates between it an the grid above.
The issue is that we would like to use the ajax filters on the block element. However, they are using the same offset when loading new content. So specific categories loaded into the block are missing the first fourposts, and often they are not in the grid about (since there are 5 subcategories under the main one).
Is there any way to correct this?
Here is the VC code incase that helps:
[vc_row][vc_column][vc_empty_space][td_block_big_grid_9 category_ids=”2281,5173,2280,31,351″][/vc_column][/vc_row][vc_row][vc_column width="2/3"][td_block_13 custom_title=”Listen” category_ids=”2281,5173,2280,31,351″ offset=”4″ td_ajax_filter_type=”td_category_ids_filter” td_ajax_filter_ids=”2281,5173,2280,31,351″ td_ajax_preloading=”preload” ajax_pagination=”next_prev”][/vc_column][vc_column width="1/3"][vc_widget_sidebar sidebar_id="td-default"][/vc_column][/vc_row]
Unfortunately at the moment the ajax filter will not work properly with the offset function. We do plan on fixing this in a future version of the theme but for the moment please do not use ajax filters and offset.
Do you have any suggestions on an alternative?
Unfortunately the only alternative for the moment is not to use the ajax filter together with offsets unti the development team can come up with a solution for the problem.
