Dear TagDiv Support Team,
I hope this message finds you well.
I have recently created a website called topbooks.us, where I write book reviews. I am using the Newspaper theme with the The Critic template, and I greatly appreciate the functionality provided in the Post Settings under the “Reviews” section.
Specifically, I am using the options such as:
“Is this a product review?” to enable the review system.
Star ratings, percentages, and points to rate books.
Adding feature names for more detailed ratings, assigning scores, and even adding additional rating categories.
Writing a review description.
All of this is working perfectly, and I find it very intuitive.
Now, I would like to know if it is possible to rank posts based on these review scores. Ideally, I would like to create a ranking system where posts can be sorted by their overall rating.
Additionally, is it possible to create rankings or filters based on different categories within the feature names? For example, if I have feature categories like “Story”, “Characters”, or “Writing Style”, could I sort posts by these specific criteria?
If this is not natively supported, could you please suggest any alternative solutions, plugins, or customizations to achieve this?
Thank you in advance for your assistance. I look forward to hearing from you.
Best regards,
Rubén Maestre
topbooks.us
Hello Rubén !
You can only sort them based on the overall score: https://app.screencast.com/qD3bz5nwG9Rkl, not the feature names.
Any other alternatives are not available because it is a theme’s feature.
For more solutions, contact our custom work team here: https://tagdiv.com/premium-customization-services/.
Thank you so much for your understanding!
