Please check this topic https://forum.tagdiv.com/topic/is-it-possible-to-insert-a-flex-block-or-a-block-between-2-paragraphs-in-a-post/
Hope this helps you!
Hi, you say:
“Simply click on the single post content element and click on the Ads tab. Here, you are able to add the code for the flex block to be display inside the post content.”
Ok, but where I can create the code for the flex block with my category an other settings for paste into the ads tab
To have the code, you need to do a new page, add in that page the block and set the filer on it, after editing it in Gutenberg editor like this https://i.imgur.com/cGNcgSS.png
