Insert adv code in posts
Hi there.
I have to insert a ADV code in my website http://www.ilgroane.it, inside every post.
Look at this post:
https://www.ilgroane.it/groane/cogliate/coronavirus-a-cogliate-la-generosita-di-un-commerciante-regala-mascherine-ai-colleghi/
I need to place code with some banners after the comments.
This is the code:
<!– ########### Ad Script for ilgroane.it_cl_widget ################# –>
<script type=’text/javascript’><!–// <![CDATA[
OA_show(3533);
// ]]> –></script>
<!– ####### Fine Ad Script for ilgroane.it_cl_widget ################ –>
I don’t understand in which file do I have to place the code.
Can you help me?
ag
You can set these ad in theme panel > ads -> https://i.imgur.com/QqVdE7a.png -> https://i.imgur.com/pX5RFcH.png -> https://forum.tagdiv.com/newsmag-header-ads/ -> unfortunately for the moment these are the only spot ads in Newsmag theme.
Hi Calin and thanks for your reply.
Unfortunately, this is not what I need.
I need to replicate what I already did on another website with always Newsmag installed.
Check here:
https://ilsaronno.it/2020/03/24/coronavirus-made-in-italy-il-nuovo-test-in-unora-e-della-diasorin-che-ha-sede-anche-a-gerenzano/
See “Related items” at the bottom of the page after comments:
https://www.dropbox.com/s/d3pr77ywklgpelo/Screenshot%202020-03-24%2016.21.45.png?dl=0
To do this, I needed to hard code template file single_template_3.php (see below):
https://www.dropbox.com/s/i7lpr9pdf2qdnce/Screenshot%202020-03-24%2016.24.23.png?dl=0
I can’t find in Newsmag version installed on ilgroane.it this file but I only have only single.php file.
Is this the one I need to change to place the code I wrote you in the first message?
Can you tell me exactly where?
ag
If that code need to be set in theme files, more exactly in single_template_3.php, than you can find this file (and rest of them) on this path -> wp-content/plugins/td-composer/legacy/Newsmag/parts/single/single_template_3.php -> https://i.imgur.com/DRlddPH.png
Updating the Core of the tagDiv Themes for Envato WordPress Requirements -> https://tagdiv.com/updating-the-core-of-tagdiv-themes/
Hope this will help you!
Thanks Calin, I missed your answer. Now I try.
Have a nice day!
ag
Hi Calin.
We have three websites with Newsmag template:
– ilsaronno.it
– iltradate.it
– ilgroane.it
On ilsaronno.it and iltradate.it I placed the code where you told me and it worked. It didn’t on ilgroane.it.
What I noticed is that some pages use single_template_3.php or single_template_4.php while other pages not.
For example, which file do I have to hard code to place code in this page?
https://www.ilgroane.it/primo-piano/coronavirus-come-vanno-le-code-davanti-ai-supermercati-di-saronno-carrefour-e-lidl/
I couldn’t find “single_template_3.php” in source code of the page so I can’t understand which template is using.
ag
If I’m right on this post you have set the default post template, this can be change in this file path -> wp-content/plugins/td-composer/legacy/Newsmag/loop-single.php
Also the post template files are compose from two php files, for example loop-single-3.php and single_template_3.php in this case the code that is not set in single_template_3.php is set in loop-single-3.php. -> https://i.imgur.com/pBUmH6h.png
