insert block 1-25 menu to post or article?
how to insert block 1-25 menu to post or article like page
http://atlantaradiokorea.com/%EB%A1%9C%EC%BB%AC%EB%89%B4%EC%8A%A4/
I like to replace related article with block menu.
http://atlantaradiokorea.com/%EB%AF%B8%EB%93%9C%EC%98%81%EC%96%B4-%ED%85%8C%EC%8A%A4%ED%8A%B8/
Visual composer works only on pages – https://forum.tagdiv.com/how-to-use-visual-composer/ You could try to use the shortcode of a block you added in Visual composer – http://screencast.com/t/aTUEgtrUefY – http://screencast.com/t/0nXHRh88sHbk and insert it in your post but there is no way to tell for sure if it will work.
The related articles comes from the file loop-single.php located here – http://screencast.com/t/vSyE3icTp You will have to modify the code in order to replace it with something else. To disable it go to Theme panel->Post settings – http://screencast.com/t/h6MGeg9yBH1h
