Theme’s modules pick the excerpt directly from post content and read more tag is used only by module 15. You can use this module on pages made with page-builder+latest article page template: http://screencast.com/t/gLjmGeCDgZSO For more details about page templates please check our documentation: https://forum.tagdiv.com/newsmag-page-templates/
Let us know if you need further assistance on this.
Thank you for your fast answer but i still can’t find solution for me.
If i understood good i can’t build new page where i can use read more tag if i want only default template? its mean i must use page builder + latest article page template?
I want to create totally new page with defatult template without last articles where i can use it read more tag is it possible?
thank you
Ivan
No you can’t use Read More tag avaialable in wordpress editor with visual composer: http://screencast.com/t/kM1fMKLzTXe The indicated tag can be used only outside visual composer in post loop settings as I’ve indicated above.
However you can use one of theme’s blocks/modules which automatically add read more button after excerpts, here in an example: http://demo.tagdiv.com/newsmag/block-12/ Block 12 use module 11 for layout and you can set a the excerpts length from theme panel > excerpts: http://screencast.com/t/iGJb5lkkl
