insert script inside tags
hi
i’m new into forum, it’s my first post
i need to insert the following code inside the body tag in newspaper theme, where to add it ? if i can do it via the theme panel or if not , how to add it manually ?
<script async src=”//service.gogo.site/js/?wkey=xdf577″></script>
any help is appreciated
Hello cortexx,
You should edit the header.php and place it your code there -> https://www.screencast.com/t/T7JEncah3f
thank you , it works !
another question, how to make shortcodes ( installed via plugin) work in combo with newspaper ? i want to insert them in the ads section, so it will be easier to save all ads in shortcodes and insert them based on criteria .
Some shortcodes work in our ad spots like for example adrotate shortcodes, but I cannot say for sure about all shortcodes. Try it out and see if your shortcodes work or not. If they don;t unfortunately we cannot offer any customization services.
