Installation problem Newspaper – News & WooCommerce WordPress Theme
Hello
I just bought it
I have two questions:
1.
I’m trying to install the td-composer.zip add-on, but I’m getting the error: “The link you followed has expired.
Please try again.”
It installs the add-on after the add-on from the plugins directory that I downloaded after purchase. Unless there is another installation manual, if so, what?
2. I want to install it on a test server first and create a template. Once I create it, I would like to transfer it to the appropriate server with the domain. Will I then have problems with installation and licensing on the production server?
Hello Marcin!
1. Which plugin did you try to install? https://forum.tagdiv.com/tagdiv-composer-tutorial/
2. I suggest installing the entire theme on a staging site, testing it, or creating the templates you like.
