INSTALLED CRYPTO NEWS PROBLEM
I installed the crypto news demo. Beforehand I backedup everything via Updraftplus back-up plugin. In the end I wanted to go back to my own customized theme. Unfortunateley, the updraftplus back up plugin doesn’t work at all. So I have to start all over again. Which is not a huge problem.
The whole reason that I installed the crypto news plugin because I liked a grid featured that they used. When I want to used the same feature I can’t costumize any because in the composer I will only see code : http://www.screencast.com/t/I6EFlNSe
As you can see almost everything is code. I am not a coder and just want to design using the visual composer.
Please help.
I realised that the grid feature can be costumized when I use the live editor. But I still can’t change some features, for example colors. The option seems to be dissappeared : https://www.screencast.com/t/wKQgFAbnj
The latest posts you exemplify in your screenshot comes from the page template. Please read this guide: https://forum.tagdiv.com/page-templates-2/
As for the colors section, this could be a plugin conflict so please disable all plugins except the tagdiv composer page builder, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Thank you, that tipped worked. Somehow I did something today I get the same problem again. But this time it won’t fix it (even with the guide I can’t solve the problem).
When you go to my website : ‘www.testpagina.brainer.nl’ and want to edit the homepage with td-composer. You’ll only get to see the code.
It’s weird because I only get to see the code when I try to edit. This means I can’t edit my homepage anymore.
Please help.
Hello brenbrinkman,
Ensure that your homepage has been made with TD Composer and not with Visual Composer because can appears some errors in this case. Notice that we do not recommend to use both page builder at the same time because might appears some conflicts.
