Installed Theme Site Does Not Load?
I have just installed Newspaper, when i activate the theme and install the plugins the site no longer loads http://www.theladtimes.co.uk, any idea what the issue could be?
Please make sure that you use this installation guide and use the FTP method to upload theme files: https://forum.tagdiv.com/installation/
Then activate it and check your site without any plugins installed to see if it works. To add plugins please use this guide and do the same for each plugin, upload and install it from the /plugins folder: https://forum.tagdiv.com/update-the-visual-composer-plugin-wpbakery/
Please let me know how it goes!
