Installing WPML Multilingual CMS disables tagdiv composer for Header and Footer
After Enabling the WPML plugin I cannot use the tagdiv composer for anything that concerns the use of Headers and footer. I can only use the tagdiv composer for the main body. If I disable the WPML plugin then I can use the tagdiv composer for the header and footer. But when I activate the WPML again my header and footer are changing to another theme and the language selection disappears/not functioning.
https://ibb.co/bX1SKFQ
https://ibb.co/hBxmg2Q
https://ibb.co/q0MZMVg
No need to answer i found my mistake!
I’m glad that you managed the situation and that you solved it.
Let me know if you need further assistance.
Have a nice day!
