I would like a suggestion of internal page template for podcasts and posts with audio player of the theme
You can add the audio file directly in media library in -> https://www.screencast.com/t/XG8WmR5kN10z
Beginner’s Guide: How to Create a WordPress Audio Playlist Without Plugins -> https://themeisle.com/blog/create-wordpress-audio-playlist/
If you want to make a page/post podcast you need to use a plugin.
12 Best WordPress Podcast Plugins Compared (Free & Premium) -> https://www.isitwp.com/best-wordpress-podcast-plugins/
eu sei de tudo isso,mas acho que meu ingl~es (google) não é tao bom assim.queri que vc meindicasse um modelo de pagina ( layout ). Algo parecido com este :https://audioglobo.globo.com/globoesporte/podcasts
ou este
You can achieve something like that using tagDiv Composer or import one homepage or a template from tagDiv Cloud library and edit it.
Here is an example with flex block 1-> https://www.screencast.com/t/0w4XQsIw9
