iOS : double Tap on links
Here is a big problem for ads earns.
If you use Chrome on iOS, then you must tap twice on a link (or a ad) to open the link.
When i don’t use “Delay JavaScript Execution” in my cache plugin, problem solved but poor speed.
  • This topic was modified 3 years by WordDom.
it seems it could be the scroll to tht top button.
How can i desactivate it on amp and mobile theme ?
Well, it’s specific to the Chrome App on iOS and on amp version with mobile theme. Even if cache plugin is disable, we have to double tap to open a link. No problem on mobile theme version.
Tested with Safari, Firefox App for iOS. Only Chrome for iOS with amp do the thing.
I’VE FOUND A BUG !
I know now what is the problem !
Use Mobile Theme+AMP, add 3 adsense amp codes in mobile theme in different locations and boom : Chrome iOS needs double tap to open links.
If you only put 2 ads or less, then there is no problem !
If you ad a third emplacment and only put a “point”, no problem. This is only when there is 3 amp codes !
  • This reply was modified 3 years by WordDom.
We can take a look and check the problem.
Please contact us via email at contact@tagdiv.com and provide the wp-admin access and include a link to this topic.
