Hi catalin,
There is a problem on iphone 5s with my site kilsanblog.com
After you scroll the site upwards, sometimes you don’t see top bar sometimes you see it partially.
I’ve checked in Samsung note 4 there was no problem.
When I’ve enabled the mobile version it is OK but it needs too much extra effort to reorganize the site. So I decided to use the standart version as it is fully responsive.
How can I repair it?
