Is it possible to change header and footer for specific category and post?
I want to create a new logo, header, and footer for a specific category and posts? is it possible?
You can use a different template for every category if you use a cloud template. You can duplicate a template, install a new one and assign it to the category you like, or create one from scratch by importing a blank template and building it as you like.
Check this topic: https://forum.tagdiv.com/topic/different-logo-in-categorypage/; Here is explained how to duplicate a header correctly and make some changes for a category template or other templates.
You can assign the template for each category in Theme Panel -> Categories.
And in post?
The same steps, you need to duplicate the single post template and set for each template a new header/footer template.
