Is it possible to order a revision of the theme
Is it possible to order a revision of the theme, in the form of two blocks based on the visual composer?
Example
Hello Iliya Stativkin,
Unfortunately, the theme does not have any such an option for it. You should try finding such a plugin for this functionality and check it how it works.
