Is Newsmag built using Bootstrap?
Naive question, and it seems answer is yes, but want to confirm.
Is Newsmag built using Bootstrap framework?
If so, is it possible to use components, as seen here, such as the panels (“Contextual Alternatives”) in posts, etc:
http://getbootstrap.com/components/
Either way, theme is working very well for us so far.
The grid it’s custom made, the bootstrap components won’t work.
Thank you, Emil G.
