Is TagDIv Newspaper theme delivering "Article Schema" for Posts ?
Yoast has alerted us to a duplication of the Article Schema that they deliver for our Posts. I have no plugins that insert Schema, so I wish to confirm – Is the Tag Div Newspaper theme providing Article Schema automatically for published Posts? I cannot find a setting to confirm, turn on, or off, and since search engines can de-rank a post due to schema duplication, this appears to be important.
Thanks for your suggestions,
Kevin
https://imgur.com/a/EI4JacK
I found the “enable article schema button” located in Post Settings of the Theme panel. disabled to resolve duplication of Yoast article schema. All set
thanks
Kevin
Had this same problem could not find the setting in Yoast or WPSchema.
