Is there a problem with menus? Is anyone experiencing the same issue?
When I try to add a new page to the menu, I get a pending error.
Does anyone experience the same issue?
I know that can happen when adding a custom link in the menu and no text is set
– http://prntscr.com/me7f49
But for pages I did not see it before. I found some topics similar to what you are describing, maybe they are helpful
– https://wordpress.org/support/topic/menu-item-pending-on-custom-and-page-links/
– https://wordpress.org/support/topic/menu-broken-new-menu-items-show-pending/
– https://blondish.net/wordpress-troubleshooting-tip-how-to-fix-the-pending-menu-problem/
Hi Simion,
Thank you for the reply.
In one of the resources you’ve send me there was a reccomendation to install the plugin WP DB Manager (from the WordPress Plugin Repository) and run the “repair DB” option.
Well, I did that and everything was fixed.
Glad it worked and thank you for the feedback, may be helpful to other users with the same issue.
Please take a look at my top menu, strange text is appearing after trying and failing to use td cloud library
http://newsite.greatcompanions.info/
My problem seems to occur when trying out event calendar plugins.
After removing the calendar plugin this text appears in wordpress above the page I’m trying to edit: Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 366 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 373 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 366 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 373 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 366 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 373 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 366 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 373 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 366 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 373 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 366 Notice: Trying to get property of non-object in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/shortcodes/vc_row.php on line 373
@pete@e-production.net So that notice is displayed when that calendar plugin is active and you try to edit that respective page? Does it happen if you edit a new page?
Could be a conflict between the theme or theme plugins and the calendar plugin. From what I can remember about that plugin for some users it worked while for others it did not and caused problems.
After uninstalling the calendar plugin, it continues to appear on my homepage design screen (not on tagDiv Composer). I only began to show up when I installed tagDiv cloud library, which I have also uninstalled for this screen shot. Where does this text reside that I can find it and remove it?
https://drive.google.com/file/d/1gkIUUpF2MTLsrXm5trB62aoFEafk-0CW/view?usp=sharing
Upon reinstalling Cloud Library I get this error when I try to use it. I was starting to like the results of my layouts but these roadblocks are killing me — and my wife who’s business is ready to kill me.
Fatal error: Out of memory (allocated 184811520) (tried to allocate 147775 bytes) in /hermes/bosnaweb16a/b1871/nf.greatcompanions/public_html/newsite/wp-content/plugins/td-composer/includes/tdc_main.php on line 609
I made sure the host (Netfirms) optimized the server per your instructions. And just before trying a different calendar app I did a complete backup, uninstall, reinstall with these results.
Pete
We could take a look at it, send us an email at contact@tagdiv.com and provide admin login. Mention how we can recreate the issues you are having and we will investigate.
I am adding text with link on home page using tagdiv editor, but after publishing
1. links are not working.
2. text can be erased with backspace.
@crazykrishna
Are you adding the text in the composer? Use a column text element for example. Test without any other plugins than theme plugins active. Plugins are the first thing to investigate.
Viewing 14 posts - 1 through 14 (of 14 total)
