Is there a way to create a text box pop up using any of elements features?
Hi Tagdiv community..
I am having trouble finding a solution that will allow me to create a text box pop up from an animated gif image I have at the top of this author page >> https://www.inspireorb.com/author/frankiecote/
Can this be achieved and if so is there a simple way of doing this?
I have looked over all the elements withing TD composer and the only thing I can find which offers a pop feature is the icon element with video popup.
I just want something that allow for text box popup with an image element.
Rhys
Unfortunately our theme do not have in tagDiv Composer for the moment any element to be display when you click on it in popup (the image/gallery are open in light-box).
Maybe this can be achieve using a plugin.
Yes I have been looking at some plugins in themeforest but most of them are only compatible with WPbakery.
Am I correct in saying, that a plugin would not enable me to add such a feature inside a page that has been created with td composer – the text pop up feature would have to be available inside the editor, is that right.
Rhys
You can try with some free plugins, maybe you can find one to work with tagDiv Composer.
You can try some plugins like this one ->Popup anything on click and set the shortcode in column text in tagDiv Composer.
