Hi guys,
On the homepage (and on pages) I was able to eliminate duplicate postings by enabling the “unique articles” element. But when I view an article (post), I see the same article’s thumbnail showing up in a category block on the sidebar (which is populating by most recent).
Screenshot: https://docs.google.com/file/d/0BwLFxEIDQNO7ZDVqRHBLaTE0ZFU/edit?usp=drivesdk
I don’t see a “unique articles” toggle when I edit a post, only on pages. Is there is a way to eliminate this from happening on post pages? Or is there another work-around?
Also, is there a way to use visual editor on posts?
Thanks a mil
Belay that last question, found out how to use VC on posts. Was hoping it would make the unique articles toggle show up, but no go.
To exclude the current post from widgets you can go to td_data_source.php file and add this code:
global $post;
if (is_singular()){
$args['post__not_in'] = array( $post->ID );
…like this: http://screencast.com/t/AmOaVxW7
Awesome, you rock Lucian. Thanks for the fix.
Replying to the mobile menu issue now. Unfortunately, that one isn’t going as well.
Actually, just noticed something. Ever since I popped that code in, the “unique articles” function for the homepage isn’t working anymore.
I tried turning it off – still duplicate posts. Then turned it back on – still duplicate posts.
Does the new code somehow disable the U.A. function?
