Issue about megamenu and subcategories
Hello, I have a doubt:
I know that is not possible to display a subcategories on megamenu, but I need to set each post with a categorie with 3th level as least. Is it possible to tag the post with subcatories without to display it on menu?
I am not sure I understand you’re request so please provide more details about what you’re trying to do, also some screens pointing the desired result will help, so I can duplicate the situation on my side and get back to you with a more accurate answer.
Ok, let me show you an example:
I have the following categories with subcategories on my site:
Praias do Nordeste > Praias da Bahia > Praia de Maragojipe
1 category with 2 subcategories. I want to display on megamenu only first level of category (Praias da Bahia), but when I set my post until the last subcategory (level 3), it shows in megamenu bottom with the others categories:
http://www.screencast.com/t/FyDljrMYf
You can achieve by adding the exclude argument in get_categories() function like here: http://screencast.com/t/RCAIqi5TLpOi Just replace the indicated numbers with the ids for the categories that you want to exclude. To get the category id follow this link: http://screencast.com/t/GfyIJar78
Hope this help.
Perfect! It worked.
Thank you very much.
Sorry but I have another issue with megamenu. I´ve noted that the maximum of links on megamenu bottom is 5, is there any way do increase this number?
To increase the subcategories number displayed in mega menu just increase this value: http://screencast.com/t/j5E9nnid6p7
Let me know how it goes!
Hi Andrei,
I have another question like this. How to increase the subcategories number displayed on category page?
Are you referring at these subcategories: http://screencast.com/t/EHKIbwQdtG If so there is no limit for them. If this is not what you mean please provide more details bout what you’re trying to do so I can inspect it closer an get back to you with a more accurate answer.
