Hello, as you can see here: https://ibb.co/hFRzGJq i have an issue in order to display comment-form-subscribe and form-submit. In order to work fixed 430 height should be 530 like you can see here https://ibb.co/KqZWXDW
I tried to insert this code in CSS but not works.. https://ibb.co/0tBVdP8
Can i have support for fix this?
Unfortunately the screenshots are no longer working, can you provide new once https://i.imgur.com/yfa2vzi.png to can see about what is this problem.
Thank you for your understating!
Here again
https://ibb.co/hFRzGJq (submit form hidden)
https://ibb.co/KqZWXDW (Height 550px with firebug)
https://ibb.co/0tBVdP8 (code not working)
Ok thanks but not works as you can see in chrome inspector
https://ibb.co/jGNLzxQ
The code should work, -> https://i.imgur.com/yfuGnWa.png as I can see in the code source, the code provide by me is not there, therefore is possible to be set in the wrong place or the cache was not clear.
If you ware using the mobile theme plugin with amp, then the code need to be set in theme panel> mobile theme > custom code> css. After that clear all cache and purge the CDN.
