SO the problem is, when I am on a desktop device everything works just fine, but on a mobile, the first block (named Dont Miss) it looks like this: http://imgur.com/myQv4h2 and only if I click on a Category (all, addictions, etc) it will load properly and show like this http://imgur.com/Q3oWlFd
How can I make it load automatically ? I dont like that it leaves a big white blanc spot 🙂
Thanks in advance.
Hello cva183,
This is not a right behaviour of the theme, strange. Please notice in our demo, here -> http://demo.tagdiv.com/newspaper/ and there you can see that the theme works fine. I suspect your issue being from your untested plugins which you are using in your theme. Please try to disable all the active plugins, leave just Visual Composer to active, clear all cache and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
Hope this help and let us know how it goes!
Thank you for the message!
FIXED: I’ve cloned the homepage to see, surprise surprise, it works perfectly if its not set as homepage. Then I thought that it might be some sort of ad or something, so I paused adblocker and BOOM! there it was, on pc also.
Turns out that Google Adsense decided to place a “Blank Add” right in the middle of my freaking Block. That was the issue… Stupid Adsense.
Hello cva183,
If you want to have on mobile mode the button back to the top, you have to use a bit of CSS code to do that. Please try the code below and place it in Theme panel->Custom CSS area.
The code is ->
@media (max-width: 767px){
.td-scroll-up-visible {
display: block;
