I’m using Advanced Ads with the Newspaper theme. When using the feature to automatically insert the ad in the post content, the ad is inserted twice. I belive this is caused by the way custom post templates are implemented as the same issue is also present with other plugins like Ad Inserter. I have already contacted the developer regarding this issue: https://wordpress.org/support/topic/adsense-ad-showing-twice/#post-11526499. Furthermore you can find more details here: https://wpadvancedads.com/manual/ad-debug-mode/.
You can see an example here: https://kreuzfahrthai.de/magazin/internet-phoenix/
Hello !
Unfortunately, the Advanced Ads plugin has not been tested with our theme and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
This is our list with tested plugins with our theme -> https://www.screencast.com/t/cmPkh9jba4sZ
thanks for your fast reply. However this is not an issue with a specific plugin. It is likely caused by tagDiv Composer not following “best practice” for WordPress plugin development and keeps me and other users from using any ad auto placement plugin. As ads are the most important source of income for most website operators I would really appreciate if you could look into it.
Unfortunately, in order to test untested plugins we need to make changes in theme files, that means custom work, and we do not have for the moment a team to do that, sorry!
-> https://forum.tagdiv.com/support-policy-2/
