If you’re using a plugin like Yoast SEO, easy to change. Or, you would have to edit the code with help from Marius/Radu. It’s typical to have site meta tag for title (look at your page source if you haven’t done so in past)…
* Default for WordPress:
Site Name » Name of Article
* Common change by most theme authors for SEO/clarity:
Name of Article | Site Name
* Some people change this to something like (I do this using Yoast SEO)
Name of Article • Site Name
Likely you can look at the functions.php file and search for the wp_title function and then edit that to your needs. (MUCH easier to use Yoast SEO!)
See: https://codex.wordpress.org/Function_Reference/wp_title
