Issue with Block title and background; Footer widget margin
Hi, I use background color for Block 7, and the margin is ugly.
issue with block title and background
Also the POPULAR ARTICLE widget in footer is missing some top margin.
issue with footer widget margin
Please help me to fix.
It seems the margins get modified on your end either from a plugin that re-writtes the css or a custom modification or css code . Please try to revert the theme to it’s default state by disabling all plugins except visual composer, clear cache and purge cdn files. Then remove any custom css or custom code you might have in the theme panel or directly to the theme files.
Let us know if you still have problems with this. if you do, please provide a link to your site so we can inspect it.
I just change the font name, no css added.
Plugin i’m using polylang, wp super cache, backwpup, Yoast SEO, loco translate, wpdiscuz
I’ll change font back to default and let you know.
the font should not affect the block title layout so please post a link to your site so I can inspect it. If you do not want to post it here, you can send us an email at contact@tagdiv.com and you can also provide wp-admin so we can inspect the back-end as well. It will help us on our search.
Bogdan B., I just send you and email with admin information. Please check your mail.
