I’m using time ago plugin in wordpress.
now i’m facing this issue:
in the category page using Newspaper block => i have always 1 month ago as date but
in post page i have 23 hours ago so that is proper date,
Please see bellow iamges
https://ibb.co/gzj5Yv
https://ibb.co/jCPTmF
https://ibb.co/gkrkYv
It seems that 1 month is a static date and is not coming from proper data format
would you please help me?
Hello mkmazid,
Unfortunately, our theme has not been tested with this type of plugin, and also, we have no idea about the theme behavior with this untested plugins. Also, we cannot say for sure if it will work or not with the theme, sorry!
The theme does not have any such an option that allows you to change the post date format but if you want to bring this functionality, you should follow the next topic here -> https://forum.tagdiv.com/topic/changing-the-date-to-x-time-ago/ because there you will find the required steps which are needed to follow in order to achieve this functionality for your date.
Hope this helps!
