For some reason, Contact Form 7 isn’t working for me on a site with the latest NewsPaper theme installed. You can test it here: https://2527sqn.co.uk/form-test/ – the form works fine when switching to the OTB TwentySeventeen theme, but fails when Newspaper is enabled.
Any ideas?
Hello rightpalava,
Make sure that you are using the latest version of the theme and notice that the Contact Form 7 works as expected with our product because was fully tested and return good results. If you are using some untested plugins, try to disable all of these, clear all the caches and check the results.
Hi Catalin – we are. 8.7.2 and the latest v5 of CF7 – also tried disabling all plugins too, still have issue.
As I said, if we disable NewsPaper and use the stock WP theme, it works fine, so it looks to be a clash somewhere with the theme and CF7 – odd I know, I use it on other sites just fine!
Hello rightpalava,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page. Provide there the link to this topic so we can quickly identify you.
